Zum Hauptinhalt wechseln
Erschienen am 4. November 2017. Modell A1865, A1901. Erhältlich als GSM oder CDMA / 64 oder 256 GB / Silber oder Space Grau. (Genauso ausgesprochen wie "iPhone 10")
1198 Fragen Alle anzeigen
iPhone X Face ID repair/replacement
Need help to replace or Repair Face ID
My iPhone X 256 GB face ID is not working after a water damage, phone is working perfectly except FACE ID, apple denied repair. Is there any way we can repair Face ID. I can't replace my mobile by paying $500
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Just Face ID or the entire front facing camera assembly?
von
I am so tired for unlock Face ID ,can you know someone how to fix Face ID !
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
In theory yes but realistically no. If you need to ask, the training and tool cost for you to start off definitely costs many times more than $500, so no.
War diese Antwort hilfreich?
Bewertung 2
it’s possible but it requires microsoldering experience and equipment. if the module is still functional, but the flex cable is bad, for example, you could cut off the module and solder onto a replacement flex (may have to be an OEM flex, but I’m not sure).
it’s a pretty intricate repair though and definitely isn’t a DIY process.
also it depends on why the face id isn’t working. I only detailed one explanation, but if it’s something on the motherboard for example, you’re getting into even more dangerous and expensive territory. and a lot of places that I know of don’t offer the same kind of warranties on liquid damaged devices because depending on how bad the damage got the device could have a heavily shortened lifespan.
Bewertung 1
Face ID parts are complicated and difficult to repair. To fully understand Face ID, you can check below.
Warum Face ID nach einer Reparatur nicht funktioniert
And for a detailed repair process, you need to pinpoint the faulty component first. Whether the flex cable has been ripped-off or relevant component has missing. Hope the following repair guide can help you somehow.
  1. Face ID not working caused by a broken infrared camera module flex cable: How to Fix iPhone X Face ID Not Available
  2. Face ID Not Available because of a missing component: Reparatur iPhone 11 Pro Max "Face ID nicht verfügbar" - Motherboard Reparatur
  3. Face ID Not Working After Screen Replacement - also flex cable broken: IPhone X Face ID fehlerhaft nach Displaytausch
iPhone X Bild
Anleitung
Schwierigkeitsgrad:
Mittel
iPhone X Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
iPhone 11 Pro Max Bild
Anleitung
Schwierigkeitsgrad:
Mittel
Bewertung 0
https://www.sosav.com/guides/mobiles/iph...
a pretty easy guide on how to repair it
Bewertung 0
2 Kommentare:
Unfortunately it appears SOSav has discontinued their English language site. The guide is still available, but only in the original French. In conjunction with the automatic translation feature of the Chrome web browser, it still works quite well even if you don't speak French.
https://www.sosav.fr/guides/mobiles/ipho...
Or you could use the guide I wrote for that same repair.
iPhone X Frontkameraeinheit tauschen
von
By the way, this repair WILL NOT FIX FACE ID! The IR camera and dot projector are both paired to the motherboard so replacing the front camera assembly will permanently disable Face ID. Only Apple can replace those parts and restore the functionality of the Face ID system.
von
Antwort hinzufügen
Vikas Reddy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 28
Insgesamt: 28,441
