Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Model A1236 / 4 or 8 GB capacity
154 Fragen Alle anzeigen
White Screen of Death + Corrupted in iTunes
My iPod Nano 3rd Gen recently stopped working. It shows a white screen and iTunes says it’s corrupted. I have tried normal restore and DFU restore. I have also opened it to check the display connector. Is the NAND dead? Is the display dead? The display has a line in it, and the iPod clicks. It makes me feel bad because this was my first handheld Apple device. Please help me!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
Nintendo Switch Kits
Eine schnelle Lösung, um wieder ins Spiel zu kommen
Switch Kits kaufen
Switch Kits kaufen
2 Antworten
Hello. I’ve seen this a lot from when I repair broken iPods. The white screen of death is fairly common. Usually I don’t bother repairing this issue because it is usually caused by loose or damaged components on the motherboard from dropping it or age. You could open it up to see if there’s anything obvious but you are better off replacing it (Or at least replacing the motherboard) It is fairly cheap to replace the motherboard yourself but buying a new one isn’t going to cost much either.
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
I don't see any damage internally. Could this still be board-related?
von
Thanks for sharing this discussion as I also wanted have the similar answer. But if your device gets interrupted so you can get Geek Squad Protection Plan to experience better work flow.
Bewertung 0
Antwort hinzufügen
TheYootz Media Group wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 28
