Zum Hauptinhalt wechseln
Angekündigt am 22. Oktober und erschienen am 13. November 2013. Das iPad mini 2 bringt die Pixelanzahl des iPad Air auf nur 7,9 Zoll unter.
426 Fragen Alle anzeigen
Super sensitive home button after digitizer change.
So I just did an digitizer change on an iPad mini 2 and now I have a super-sensitive home button. Any one knows why? I just have to lay my finger on it an it will react. Double tapping it will bring up Siri. Also putting some pressure on the right side of the home button on the glass will give the same reaction as to using the home button. Some problem with grounding points?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Use the home button that on previous touch,The new one with touch not working well i also faced that issues before.
War diese Antwort hilfreich?
Bewertung 1
Did you reuse the old home button?
The new digitizer May have a slightly uneven or differently sized hole or button. It could have uneven pressure on it.
Bewertung 0
2 Kommentare:
Could also be due to not having yellow kapton tape behind the screen at the bottom digitizer touch screen borders and the home button cable.
https://images-na.ssl-images-amazon.com/...
von
Screen had kapton, although no protection for the home flexcable. Put some plastic over it and the issue dissapeared.
von
Antwort hinzufügen
patrick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 43
