Zum Hauptinhalt wechseln
Repair guides and support for the Expedition, a full-size SUV based on Ford's F-150 pickup truck. Closely related to the Lincoln Navigator.
50 Fragen Alle anzeigen
theft light only lights up for two minutes then off. Why won't it star
Okay so I have a 98 Expedition and I lost my only key so I had to drill out the old ignition in order to get it to the on position to take the cylinder out. In the process the Pats transceiver that goes around the lock was damaged. So I go to pick a part grab another transceiver, installed it i got a new ignition with two brand new chip keys installed and I go to turn it on and it won't start. ot turns over but won't start. I read How to cycle in and program two new keys. In that description it says the anti-theft light will continuously blank for 15 minutes. My theft light will only for 2 minutes then shut off. I figured if I wait till it shuts off will try to start it then but it still won't start. And the theft light will not come back on until I turn the car off with the key and turn it back on and then it'll come on for 2 minutes and then shut off again. what do i do?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
2 minutes is your tell tale sign, you got the wrong part number for your transponder, go to the dealer and make triple sure your VIN number and transponder part number are made for each other. Just tell them this one is wrong please. Also make triple sure you didn’t damage anything else down there.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
i found the exact same part. same exact part number. now the light blinks for 15 minutes. I have read how to cycle in a new key but battery keeps dying. while i was trying to program a new key it started beeping 5 times five separate times. what's that?locksmith said he'd program or for $50. hope it works.
von
Antwort hinzufügen
Alex Pittock wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 1,020
