Zum Hauptinhalt wechseln
Repair and disassembly guides for Kenmore Microwaves.
182 Fragen Alle anzeigen
No power getting to microwave.
microwave stopped operating and display went blank. Unable to get it to work. AC outlet is working fine,tried unplugging unit and re-plugging unit with no response,display totally blacked out, wondering if it's power cord,how can I evaluate this problem?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
you could check the fuses on the power cord..but even if they have blown I'd still throw this away... the fuse blew for a reason!
microwaves are cheap, and repairing them seems to be something that none of us here are willing to undertake....the risk to you is too great!
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
If you insist on working on this, take out a lot of life insurance. But that might nor work as it may be considered suicide, not accidental.
von
If you have a bit of electrical know how, my dads microwave did the same thing and the fuses kept blowing. There is a power unit inside that had a 4 bridge rectifier. The rectifier is heavy duty and capable of carrying about 20 amps at 120 volts. Beware: there are also very large capacitors that can kill which remain charged even after the power has been disconnected.
To make a long story short, I bought a new (but different shape) rectifier and made a new mounting hole in the heat sink and ran some wires from it to the circuit board. To test the power supply check for continuity at the ac input terminals of the power supply. If shorted check the rectifier on the terminals marked ~. if shorted un-solder it from the board and find a replacement.
Bewertung 0
1 Kommentar:
James, I removed your email address. It will protect your privacy and will protect you from spambots. Do it like the rest of us and add it to your profile.
von
Antwort hinzufügen
Warren wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,843
