Zum Hauptinhalt wechseln
The Chrysler 300 was designed as a modern interpretation of the Chrysler C-300, featuring a large grille, long hood and low roofline that was prominent on those vehicles.
How do I fix a open closed loop on my 2006 Chrysler 300
It said I had a bad fuel injectors and it said circuit 2 so I change that and then it said something about a fuel Loop and after I changed injector it still made a ticking noise and the code reader said the same thing
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Never trust a code reader, have the items that the code reader said is bad inspected directly with an oscilloscope. Your explanation of the problem needs to be a more detailed explanation please. What was the code exactly. In order for a computer to go into Closed Loop, the oxygen sensors need to be fully hot and working. You mentioned circuit 2, that may be Bank 2 or it could be sensor #2. We don’t fully understand your problem, more details please. Also what is clicking? One of your fuel injectors is making clicking sounds?
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Amanda Phillips wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 33
Insgesamt: 758
