Zum Hauptinhalt wechseln
Die Wi-Fi Version von Apples iPad 6, erschienen im März 2018. Erhältlich mit 32 und 128 GB Speicher. Ausgestattet mit einem 9,7" Retina Display und einem 64-bit A10 Fusion Prozessor.
150 Fragen Alle anzeigen
Can't turn on WiFi, Bluetooth doest find devices.
I recently successfully replaced the digitizer on my iPad 6th Gen (WiFi) after using for about 2 days, the iPad rebooted itself, and now WiFi switch is turned off and greyed out, and Bluetooth just keeps searching for devices and can't find anything. I tried resetting network settings, rebooting my gateway modem, and restoring to factory settings. Nothing worked. What I am wondering is would a bad antenna cause these issues, or if the antenna is bad would I just have crappy reception?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
It’s possible that you may have successfully repaired the screen but damaged the connection on the iPad itself. If it’s greyed out from my experience that generally means that someone inside the iPad is damaged. Only way to fix it is to open it up again and check
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Generally it turns out to be the wifi chip going bad if that's the case the logic board would need to be replaced otherwise time to get another iPad.
It's actually quite rare for these to go bad on iPad air and newer iPads.
Double check the two antenna connectors near the screen connectors on board as they can get unplugged accidentally rare but does happen.
von
Antwort hinzufügen
Joshua Holder wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 96
