Can I use a pc hard drive for boot camp
I'm about to install windows 7 but i don't want to waste any hard drive memory so can i use my old pcs hard drive to use boot camp on there ?
Ist dies eine gute Frage?
I don't think it's possible to run Windows from an external on a Mac. In order to run windows on Bootcamp there are drivers that need to be installed. What you can do is use WinClone to clone the Windows drive into an iso image then use bootcamp to transfer the iso over to that partition. But there is no way to physically use that drive as an external and boot to it from bootcamp. Now that i think about it, theres no way to boot into an external with Windows OS even from a Windows machine, well, at least not with a USB interface, not sure about FireWire.
War diese Antwort hilfreich?
Just a correction to your post Majesty,
It is possible to boot into an external drive/Flash drive from Windows. You need to ensure the BIOS allows you to boot from the device. If a computer won't allow it you may need to consider flashing your BIOS if possible.
I have a flashdrive that can run many verisions of Linux and Windows if I choose.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,764
5 Kommentare
Are you using an external enclosure with the PC hard drive?
von mayer
what does that mean?
von jonathancha
Is it outside the box?
von mayer
yes it is... sorry i had to put the three periods to add the comment
von jonathancha
What are you using the Windows side for? If it's something like Gaming, you wouldn't want to do that from an external drive. If it's for something like day to day finance or thereabouts... then using an external hard drive would be fine. I'd personally suggest VMWare Fusion or Parallels to setup Windows. You can define the location of your virtual machine and even transport it from one drive to another if necessary.
von Josh
