Zum Hauptinhalt wechseln
Modell A1502 / 2,6 GHz (Turbo Boost bis zu 3,1 GHz) oder 2,8 GHz (Turbo Boost bis zu 3,3 GHz) Dual-Core Intel Core i7 Prozessor mit 4MB geteiltem L3 Cache.
494 Fragen Alle anzeigen
Why is it Booting Up Twice?
Hello all,
Recently upgraded the SSD on my Mid 2014 13” Macbook Pro. Bought a 480GB OWC Aura Pro X2 SSD which was pretty easy to install and the only thing I had to do for a successful install was upgrade the OS to High Sierra 10.13.6 for drive compatibility.
I created a final backup with Time Machine, installed the new SSD, reinstalled the OS and everything works just fine, minus two incredibly annoying things started happening.
  1. Whenever I boot my Mac, it has to do it twice and it’s quite slow. I press the On button, it chimes once, it backlights to black, apple logo doesn’t appear. Then turns off, it chimes again automatically, backlights to black, long wait then the apple logo appears together with the loading bar and it’s all normal from then onwards.
  2. When I close the lid to put it on standby and then reopen it, it very often doesn’t turn on again. It backlights to black, so the laptop is indeed still working but won’t do anything else, so I have to hard-reboot it in order to use it again.
Another weird symptom is that a couple of times I just shut the lid and didn’t reopen it for a few hours, the mac was red hot and the fan was going crazy!
Using certified diagnostic softwares didn’t flag up anything wrong hardware-wise. Tried resetting the PRAM but didn’t do anything to it.
Can anyone please help with any suggestion on what to do?
Many thanks!!
Ist dies eine gute Frage?
Bewertung 2
6 Kommentare
Did you talk with OWC? They do have a firmware update that was needed on some drives.
von
I have sent OWC an email but haven't heard back yet.
von
Hi Scott,
Any joy fixing this problem.
I have a similar issue?
Thank you Andrew
von
OWC is aware of the problem but I haven't seen a fix to it yet. The only thing they suggested was to keep the computer from going into shutdown and having it go to sleep instead. Every time I reboot it will still hang or boot again before starting up.
von
Hi Scott did you get this issue fixed in the end? I seem to have the same issue
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Next time you get it booted go into
System Preferences > Startup Disk and select your drive.
Reboot holding down the P,R, Command and Option key and let it tone three times while holding down those keys.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Fabrizio wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 21
Insgesamt: 2,331
