Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Vierte iPad Generation, erhältlich seit dem 2. November 2012 mit 16, 32 oder 64 GB Speicherkapazität. Modellnummerb A1458.
233 Fragen Alle anzeigen
error 9 , error 40
Hi , i have an ipad 4 which suddenly showed the apple logo during normal use . when i tried to update / restore i got error 9 , i tried a new lightning port , new battery , tried a restore with reiboot pro . also tried another pc and a macbook for the restore …
I removed the board and used naviplus pro to read the nand chip , seems ok , i also repaired the nand with naviplus and tried to restore again , now i get error 40 . , i’m thinking now may be cpu , is there a test to confirm this ?
..here is a link to the itunes restore log
https://www.dropbox.com/s/3al0q9okudom8e...
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
I,m not sure if i’ve made progress with this or not , i gave the nand chip some heat , plugged it into the naviplus again and noticed the model no R/M . box was blank , i filled this in and it restored ok . now i have activation error !!  ,,  its a wifi only model and i tried the restore with pc and a macbook , same result ,...
von
Einen Kommentar hinzufügen
SPAR DIR DAS UPGRADE
Mach dein iPhone so gut wie neu mit unseren Fix Kits.
Jetzt entdecken
Jetzt entdecken
1 Antwort
all the way at the bottom of the restore log it says this
[19:07:11.7430] Depth:2 Code:40 Error:storage device did not become available
maybe it is your storage device that is bad, and not a cpu.
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
so that would suggest the nand chip , i thought that as the naviplus machine was able to read and write to it ok that would rule that out ..
von
Antwort hinzufügen
markparnell1972 wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 4
Insgesamt: 110
