Zum Hauptinhalt wechseln
Veröffentlicht im Juni 2015. Android OS, v5.1 8 oder 16GB Speicher, microSD Kartenslot
45 Fragen Alle anzeigen
Why Samsung J5 won't power up with power supply?
Hi, I was a cell phone repair and after several years spending out of this career I came back to the business again.
I have a Dazheng PS-305D DC power supply which works almost fine, but it can’t power on some new phones mostly Samsung phones.
I put the power supply current to maximum and the voltage on 4.0
When I press Power button,the phone starts and after showing logo of what manufacturer it is, it boots again and again. it never comes up.
It should be noted that this happens to 70 percent of phones.
So, what do you think? Is it a problem with my power supply? Am I doing anything wrong?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
you set the power supply to 4 volts, and most phones need 5volts, and 1 amp if you look here it says the samsung j5 charges at 5 volts
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I know how much voltage it needs to charge the battery, but I put the probs instead of the battery, which means the power supply should play as a battery and the batterys output must be about 3.7 voltages
von
Antwort hinzufügen
Hooman l wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 195
