Zum Hauptinhalt wechseln
Scientific calculator by Casio. Widely used by students world-wide due to its great quality for the low price.
How do I fix my calculator that only runs on solar power?
My Casio fx-991ES PLUS was dropped and now the display does not light up unless it is under a light source. It has a mini solar panel which I assume it using for power and it has new batteries in it but they do not seem to work. Is there something I can do to fix it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 6
1 Kommentar
I replaced mt calculators
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@madrthanevr could simply be an issue of torn wires/ connectors or something more sinister like an issue with the power management IC on your PCB. We’d need to see what is going on inside your calculator Bilder zu einer vorhandenen Frage hinzufügen
War diese Antwort hilfreich?
Bewertung 4
3 Kommentare:
Thanks @oldturkey03 there was just a disconnected wire. Probably should have checked beforehand. Much appreciated!
von
My casio MJ-12D is not working after putting in sunlight.....what should i do for this??
von
@madrthanevr how did you check the wiring? I have a similar problem
von
Casio can replace the broken screen, they will give you a price before they do the repair, by the time you add shipping to them and shipping back to you, you will be better off just buying a new calculator and keeping this one for spare parts for the next person who wants to buy a motherboard.
Bewertung 0
Antwort hinzufügen
MadRthanevr wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 42
Letzte 30 Tage: 112
Insgesamt: 25,633
