Zum Hauptinhalt wechseln
Repair guides and troubleshooting for Acer Predator 17.3" laptops, a group of high-end gaming computers from Acer. These laptops features a 17.3" display, dedicated GPU, and a modular bay for either an optical drive or cooling module.
Is my charging port still working?
My laptop was plugged in and charging. Came back to a flooded room and the adapter was totally submerged. The laptop is still working but the adapter is damaged.
The socket it was plugged into is currently not working as well.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi Nana Kwame
You mentioned that your laptop work and the adapter is damaged.
The easiest way is to test it, either find a spare or test it directly at the computer shop.
If the replacement adapter works, you purchase it. I think most shop are generally fine to do this test.
Do not test the old power adapter as it is not recommended. Most probably it has been shorted out and water will start working inside the circuit, damaging it further, corrosion and misc.
For the socket, I presume it is your power outlet.
There are some possibilities, either water is still inside the plug thus circuit breaker has been activated to cut off.
internal power socket has been corroded or damaged by water, so as the wires which might be damaged / rot.
For the power outlet, if you are unsure, check with a qualified electrician for troubleshooting.
Somehow I also think if you have insurance, you might like to check if they cover those damages, which you can claim on.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
I've orderer a charger, should arrive in a week or two
von
Antwort hinzufügen
Nana Kwame wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 24
Insgesamt: 379
