Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Modell von 2011, A1278 / 2,4 GHz i5 oder 2.8 GHz i7 Prozessor.
610 Fragen Alle anzeigen
Can't install OS X
I’m currently using OS X Lion 10.7.5 on my MacBookpro because I like it but recently certain websites haven’t been working as well so I decided to upgrade to El Capitan but when I start the installation I get this message
OS X cannot be installed on “Hard Drive”
I had the 500GB hard drive replaced last year with a 1TB hard drive, so maybe that’s the problem.
Also, if this helps the processor is 2.4 GHz Intel Core i5 and the memory is 4 GB 1333 MHz DDR3 and the graphics are Intel HD Graphics 3000 384 MB
Edit:
I just tried again and when I clicked on the hard drive icon I got this message
This disk is used for Time Machine backups
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
SPAR DIR DAS UPGRADE
Mach dein iPhone so gut wie neu mit unseren Fix Kits.
Jetzt entdecken
Jetzt entdecken
2 Antworten
Gewählte Lösung
I found the solution.
There was an empty Backup file in my Hard Drive, so I deleted the file and was then able to perform the update.
BTW if you’re still using Lion, I would recommend updating to El Capitan, any bugs the at it had on first release have al been fixed so it works like a dream and it’s given my machine a new lease of life.
War diese Antwort hilfreich?
Bewertung 0
Go into your System Preferences open Date and Time. We did to alter the date manually to Jan 2016. Make sure you disable the check mark. Restart your system and see if that fixes things.
Bewertung 0
Antwort hinzufügen
rob7037a wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 25
