Why won't my dryer start
Why won't my dryer Start? I replaced door switch, thermal fuse, all thermal sensors, heater coil, motor, and lightbulb. Getting power to dryer and checked continuity in start switch. Lightbulb doesnt come on and it wont start. Please help!!!
Ist dies eine gute Frage?
4 Kommentare
Hi @kirkyboo ,
What is the full model number of the dryer?
What was the original problem?
von jayeff
My model number starts with 110. The original problem was the dryer would shut off early. I now have replaced everything but the start switch and end of cycle buzzer. Now when I touch the power wire from the start switch to the body of the dryer it wants to start. But the lightbulb still doesnt come on when the door is open. Is the ground wire from the start switch causing the problem?
von Kirk Naegler
@jayeff I posted a follow up but still having trouble navigating this website. My model number starts with 110. The original problem was the dryer would shut off early. Now I have replaced the timer and it still won't start and the light doesnt come on with the door open. I accidentally touched the power wire from the start switch to the frame of the dryer and it wanted to run. Could the ground wire from the start switch have come loose behind the drum and panel that houses the light?
von Kirk Naegler
Will the signal switch cause a no start and/or short?
von Kirk Naegler
