Zum Hauptinhalt wechseln
Modell A1502 / 2,4, 2,6, oder 2,8 GHz Dual-Core Intel Prozessor / Erschienen im Oktober 2013
Would a 2015 13" MacBook Pro battery be compatible with a late 2013
Would a 2015 13" macbook pro battery be compatible with a late 2013 a1502 13” macbook pro. Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The A1502’s from 2013-2015 use different model no batteries A1493 and A1582. They are both cross compatible. But if possible try to match the battery model number.
I’ve used vice-versa and it has worked either way.
War diese Antwort hilfreich?
Bewertung 5
3 Kommentare:
Alright thanks, I've got a 2013 a1502 that arrived with no battery. Is there anyway to figure out which one it had? Thank you
von
That one used the A1493 battery. Getting the a1582 battery is a better choice as the battery cells will be newer and better than a battery that was made in 2013.
von
For what it’s worth, I ordered a 1502 battery and ifixit sent me a 1582. The fit took some effort, as the fit wasn’t perfect, but I got it in. And it works!
von
Antwort hinzufügen
Callum Menzies wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 26
Insgesamt: 837
