High beam headlights don't work, only the low beam headlight works
I have a 2005 Altima in Canada with a Running Lights Module. Checked the fuses but the High beams don’t seem to work, and only the low beams seem to work.
Ist dies eine gute Frage?
@raezorsharp check the headlamp high relay, located in the IPDM E/R (intelligent power distribution module engine room).
“High Beam Operation/Flash-to-Pass Operation
With the lighting switch in 2ND position and placed in HIGH or PASS position, the BCM (body control module) receives input requesting the headlamp high beams to illuminate. This input is communicated to the IPDM E/R (intelligent power distribution module engine room) across the CAN communication lines. The central processing unit of the IPDM E/R controls the headlamp high relay coil. When energized, this relay directs power
* to terminal 1 of headlamp RH, and
Ground is supplied
With power and ground supplied, the high beam headlamps and the HIGH BEAM indicator illuminate.
For proper troubleshooting check the lighting part of the FSM Altima-Lighting-.pdf which does included the Canadian lighting system
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 687
