Zum Hauptinhalt wechseln
Mid 2010 Modell A1278 / 2,4 oder 2,66 GHz Core 2 Duo Prozessor
794 Fragen Alle anzeigen
Mid 2010 MacBook Pro completely dead.
Macbook pro will not turn on and there is no light on charger. I tried all of the steps apple recommends but nothing happens. When I hit the button on the side no lights appear no lights and charger works. Please help.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Your battery clearly needs a charge or replacement!
I would review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters
Make sure you are using a REAL Apple charger! There are a lot of fakes! These fakes can damage your system in a few different ways. The first is damaging the MacBook Pro Unibody 13" and 15" MagSafe DC-In Board carbonizing the gold contacts so the connection with the MagSafe is not being made. From what you describe I’m suspecting that’s your problem. Here’s the guide you’ll need to follow to replace it MacBook Pro (13 Zoll, Mitte 2010, Unibody) Versorgungsplatine (DC-In Board) tauschen and don’t forget to get a new charger! Here’s what your fake charger did Lacking safety features, cheap MacBook chargers create big sparks
After replacing the DC-In Board: If your MagSafe charger is Green then your logic board has a problem. If it’s Amber then you need to let it charge the battery for a good 10 hrs! Then see if it starts. IF it does download this gem of an app CoconutBattery. Take a snapshot of the main window and post it here for us to see Bilder zu einer vorhandenen Frage hinzufügen.
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board Bild
Produkt
$9.99
MacBook Pro 13" Unibody Mid 2010 Versorgungsplatine (DC-In Board) Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
45 minutes
iFixit Bild
Anleitung
Schwierigkeitsgrad:
Sehr einfach
2 - 5 minutes
War diese Antwort hilfreich?
Bewertung 1
Comprehensive reply Dan well done. If none of that works, start watching Louis Rossmann videos on Youtube and diagnose which power rails you are missing and go from there
Bewertung 0
Antwort hinzufügen
magicjet wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 247
