Zum Hauptinhalt wechseln
Die Playstation 3 (im Volksmund auch PS3 genannt) ist das dritte Heimcomputer-Unterhaltungssystem der Firma Sony und der Nachfolger der PlayStation 2. Sie erschien am 11. November 2006
781 Fragen Alle anzeigen
Not sure what you'd call this (Post attempt #3)
3nd time posting this because for some reason the last 2 posts were marked as “innapropriate” and deleted.
A long time ago, my PS3 model CECHE01 stopped transmitting video to any TV. Recently, me and my brother have tried to fix it. Here’s the symptoms:
  • The PS3 turns on with a green light, but no video is displayed.
  • The only thing that will display is the safe mode menu.
  • When we insert a disc into the drive, the blue light will turn on.
  • Controllers can be plugged in and charged.
And here’s what we’ve tried:
  • Resetting the settings. Safe mode does appear, but when we hit an option, it stops transmitting video again.
  • Blowing any dust out of the system with compressed air.
  • Other options in the safe mode menu. The only other one we’ve tried so far is “Restore File System,” or whatever it’s called.
  • Using AV and HDMI. Neither video output worked.
Any idea as to what to do next?
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare:
Not sure what I did differently, but it's not marked as innapropriate this time! Hooray!
von
@sc00tin double checked your previous attempts and could not see anything wrong with it. I removed the prior two attempts in a way that reversed the penalties on your reputation.
Now, let's see if anyone can help you with that. @tronicsfix is the console guru on here so let's see if he can help you out.
von
Wish I could help but I don't know much about the older systems. Sorry
von
Einen Kommentar hinzufügen
1 Antwort
Make sure that the red,white, and green wire are plugged in
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
wait, green wire?
von
Antwort hinzufügen
Firstname Lastname wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 33
