Zum Hauptinhalt wechseln
Veröffentlicht am 16. Oktober 2014, Modellnummer A1347 - EMC 2840
186 Fragen Alle anzeigen
"Fusion" or "RAID 0" PCIe SSD to SATA 3?
OBJECTIVE: Create the fastest Mac Mini ever by either Fusion or RAID 2 SSD’s.
HARDWARE: 512GB Samsung PCIe (Apple SSUBX '''blade) and 512GB Samsung 2.5 ('''860 EVO Pro)
DILEMMA: I have never seen either done. Is there a reason other than cost per/GB?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
RAID setup require two interfaces (same) and drives which are running at the same I/O speed. Thats not possible in this series! Here you have a PCIe/NVMe interface and a SATA interface.
Fusion Drives are a compromise! Leveraging the SSD as a cache to the slower HDD. Thats why the SSD’s Apple uses are on the small size. Using slightly larger SSD’s can be helpful at some point the benefits drops like a stone and the costs become wasteful!
The best you can do here is setup a dual independent drive config! Get a 500 GB or larger PCIe/NVMe blade SSD set it up as your boot drive hosting your apps. Leave the rest of the drive empty so the OS can leverage it for virtual RAM, caching & paging. If your apps use scratch space make sure its setup to use the SSD. Use the HDD as your data drive. If you need to upgrade it consider doing with a SSHD drive. Going with a 2.5” SSD doesn’t offer any true benefit in this config given the cost.
References:
The Ultimate Guide to Apple’s Proprietary SSDs
Seagate FireCuda 2.5” SSHD
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
applerepairshop wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 37
