Zum Hauptinhalt wechseln
A1708 / EMC 2978 - Dieses MacBook wurde Oktober 2016 als Einsteigermodell seiner Klasse eingeführt. Es kommt mit den klassischen Funktionstasten, sowie zwei Thunderbolt 3 Anschlüssen und einem Intel Core i5 Prozessor.
216 Fragen Alle anzeigen
Not charging but charge icon indicates charging
Laptop status - will not charge at all or turn on (presumably because the battery is now 100% drained)
Some info:
  • Prior to the problem the taskbar battery icon was the ‘charging’ one even when removing the usb-c charger
  • Once had a day-long issue with the trackpad not being clickable (seems like this could have been due to a ‘swollen’ battery)
  • I am using the official power brick and cable, however I was using those with a UK plug adapter purchased from eBay/China (originally bought the laptop in US)
  • Battery condition was displayed as ‘Normal’ in system info, however I did used to deplete it below 5% quite frequently. Have used the laptop as a daily driver since early 2017
  • Occasionally when charging the unibody would have a bit of a static / vibrating feel to touch (has anyone else experienced this?)
So what do you guys think? I have seen some people say I can attempt to disconnect and reconnect the battery, other say to go for a new battery.
I’m inclined to think the problem does not lie with the power source due to the odd behaviour on the machine when plugged / unplugged, seems the problem is internal
Thanks in advance for any help
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Are you using the original Apple charger as well as the power USB-C cable that came your system?
You’ll want to get a USB-C power meter so you can really monitor whats happening Satechi USB-C Power Meter Tester Apples rush to minimize ports sorta forgot how to monitor power effectively.
You also sound like your battery is failing! Apple has a extended warranty on some MacBook Pro’s you should check to see if yours is covered 15-inch MacBook Pro Battery Recall Program''''''.
In any case you’ll want to install this gem of an app CoconutBattery so you can better monitor your battery health.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Lewis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 55
