Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Modell von 2011, A1278 / 2,4 GHz i5 oder 2.8 GHz i7 Prozessor.
557 Fragen Alle anzeigen
Usb ports will charge phone but won't connect
I have a MacBook pro a1278 2011 both USB ports will will not connect to phone but will charge I have tried different cables yes factory different phones and won't read jump drives have tried smc and nvram reset and no change
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
There’s nothing else one can recommend for such a problem on a DiY basis beside the resets you already did. It seems power is fine but data can’t be properly exchanged and that just leaves a just board failure as explanation, I’d speculate at Usb Mux level. Either you can find someone doing component level repairs or you’ll have to replace your board. You may try a Thunderbolt to Usb adapter as a workaround but I’m not sure that will work fine.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Charles Friend II wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 7
