Zum Hauptinhalt wechseln
Dritte iPad Generation mit Wi-Fi, Modellnummer A1416, erhältlich seit dem 16. März 2012. Die Reparatur erfordert Hitzezufuhr und vorsichtiges Hebeln.
154 Fragen Alle anzeigen
Ipad screen gone black
A couple days ago I dropped my ipad about 2 inches high onto my leg. the screen went black. I tried the rebooting sequence but it doesn’t help. Power still gets to it, as went it is turned on, you can see a slight but almost unnoticeable change in the brightness of the black but you have to be in the dark to notice it. Now would it be the screen gone bad or the display driver?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Try shine a bright light to the screen at boot or when toggling power button to check if you have a dimmed out image or no image at all. In first scenario there’s a higher chance of a board backlight issue whereas in the second an Lcd failure would be more likely. Yet, we are just talking about probabilities, without known good parts or tests one can never be 100% sure.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Did try shining a light on the LCD display. It was still completely black.
von
@johntanguay An Lcd replacement would be the most reasonable first step then.
von
Antwort hinzufügen
John Tanguay wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 45
