Zum Hauptinhalt wechseln
Anleitungen zur Reparatur und zum Zerlegen von Handys aller Hersteller und Service-Anbieter, inklusive Apple iPhone und Samsung Galaxy. Alles, was du brauchst, um dein Handy selbst zu reparieren.
73380 Fragen Alle anzeigen
Why isn't it working?
So I accidently got water in my phone ,then I left it in a bag of rice over night then when I turned it on the next day the screen stayed blank and then it started making ringtone noises and it still won't work…what do I do?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Rice is for eating, not for drying phones out
von
Einen Kommentar hinzufügen
2 Antworten
One day is not long enough for the water to dry if your phone was in a bag. If you can, try removing the phone’s battery and laying everything in front of a fan so it can dry a bit faster.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thank you I'll try it x
von
depending on your phone Rice may not actually do anything at all.
phones these days are compact tightly designed machines and for rice to work it has to come into contact with the water more or less. the water isn’t able to escape towards the rice so it stays in the device.
first step is to remove the battery and clean the motherboard. isopropyl alcohol should be enough if not much corrosion has occurred. when that’s done based on your description you most likely need to replace the screen assembly. of course it’s also possible the water did permanent damage to the display circuit which would require a specialist to fix.
if you give us the model # of your phone it could help us help you as well
Bewertung 0
Antwort hinzufügen
Ashia Begum wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 34
