Zum Hauptinhalt wechseln
Verkaufsstart Juni 2012, Model A1278. Intel Prozessor mit Turbo Boost
1624 Fragen Alle anzeigen
New Trackpad doesn't work
Hi, I bought a brand new trackpad from iFixit, installed it without too much trouble and sadly found out it barely registers any movement when I turn the machine on. It’s actually worse than the trackpad I replaced. I am trying to figure out if this is a bad part, or if there is something else that might be wrong. This computer works fine with pointing devices attached through bluetooth or USB. So, what do you think? Bad part, or something else wrong?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Did you replace the trackpad cable as well?
von
@danj - Yes, that is assuming it is the little flat cable that plugs into the back of the trackpad and then into the motherboard.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Please check your battery for swelling.
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
I replaced the battery as well, no swelling and the new battery seems to be functioning correctly...
von
Did you adjust the trackpad using the adjustment screw?
von
Yes. Tried it a number of ways. No luck. iFixit is sending a new trackpad... I'll give that a try.
von
Antwort hinzufügen
Peter Frank wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 53
