Zum Hauptinhalt wechseln
Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
Where can I get a USB charging cable for this drone?
I have misplaced the USB charging cable that came with the DX-2 stunt drone. Where can I get a replacement USB charging cable for the DX-2 drone?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi,
Did you mean the charger including cable or just the cable itself.
Chargers are available online, here’s an example. Just search for Sharper Image DX-2 drone charger to get results for suppliers that suit you.
Looking at the charger it appears that the charger cable has the standard micro USB connector, so if you have a standard mobile phone charger which has a micro USB connector plug on the cable you should be able to use it to charge the drone.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
George Riley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 34
Insgesamt: 1,707
