Zum Hauptinhalt wechseln
ASUS Zenbook Flip S UX370UAK(old) / UX370UAR(new) 2in1 Convertible, Pen-Support, Fingerprint
7 Fragen Alle anzeigen
What screw size is it?
I have Asus Zenbook ux430u and I want to replace some parts but I don’t know which screwdriver I should use.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
TORX T5. You'll find this in many kits.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
T5 or T6 for the Zenbooks - it depends on which one you have, so I would get both just in case. It isn’t a TR Security at least, so that isn’t an issue. More then likely it’s T5 because that’s historically what Asus uses in the Zenbook, but T5 and T6 are very similar looking to a point on devices like this, it’s best to have both. It uses Phillips #00 screws like nearly every other laptop in the PC sector internally.
I would also get the 64-bit driver kit just in case it’s something obscure even what information I have doesn’t apply. You’re better off with the 64-bit driver kit since it isn’t that much more, if you want to save a few bucks, the Marlin screwdriver set will work. This only has the T6, so you’re taking a chance on if it will work or not as well.
Mako Driver Kit - 64 Precision Bits Bild
Produkt
$39.99
Marlin Screwdriver Set - 5 Torx Precision Screwdrivers Bild
Produkt
$19.99
War diese Antwort hilfreich?
Bewertung 1
5 Kommentare:
thank you very much:)
von
does anyone know what the actual size of the screw is as well? I'm trying to find replacements but I can't tell what the size is.
von
@Talal Hasan Usually Asus is T5 - look up the model and you'll know right away.
von
Guys, I lost them after I removed the screws. Can you tell me their model number? (like M2 * 4). There should be two kinds of screws on the D side.
von
@zpp eBay. Buy a bunch of them for a few bucks, but keep in mind unless you seek out T5/T6, they will be Phillips.
von
Antwort hinzufügen
Anton wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 15
Letzte 7 Tage: 120
Letzte 30 Tage: 405
Insgesamt: 12,008
