Zum Hauptinhalt wechseln
Refrigerators produced by Samsung.
159 Fragen Alle anzeigen
Why won’t my refrigerator stay cool?
We have been having difficulty keeping our refrigerator and freezer cool lately. After pulling the plug and resetting it it does cool to a normal temperature. It also stays cool if we use the power cool mode, but when we use the regular cooling modes the refrigerator warms up rather quickly.
there was some noise a week ago or so for a few days. No noise now though.
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare
Hi,
What is the model number of the refrigerator?
von
The model number is rf265aash
von
I have got this exact same issue.. Did you a solution for this already?
von
Having Refrigerator cooling issue....replacing Evaporator Fan. just received fan. Repair manual is online so you can check the manual for error codes that might lead you to the trouble.(we had a Evaporator Fan error)
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi,
Here’s a link to the service manual for the refrigerator.
Go to p.43. Start at Sect 4-1-3-2 Self-diagnostic function during normal operation and check if there is an error code being generated after you have manually start the diagnostic program.
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Thank you. This is very useful information. Maybe I should have let it run for 24 hours.
I’ll let you know if we figure it out.
von
So far we ruled out the condenser, both fans, and the evaporator. It seems to have something to do with the temperature. If we set the the freezer and the fridge to power cool they go below the wanted temperature. If we turn off the power cool the refrigerator warms up quickly.
von
Hi,
Did you try the " If Power Freeze + Power Cool Key are pressed simultaneously for 8 seconds (including above 2 seconds), self-diagnostic function will be selected" to see if there is a error code generated?
Here's a link to the page.
von
Freezer is what keeps the fridge cold so if there both failing its the fridge that has a problem first thing to do is clean the back and fan and coils ,cooling fins , if thats not the problem check the compresser fan to see that its running if so compressor could be faulty or need checked leave anything past cleaning and fan replacement to a tech check both fans and clean under it and behind it take plate of the back after its unplugged take big paint brush and shop vac and clean everything you can get to
Bewertung 0
Antwort hinzufügen
marymikesmith wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 3
Letzten 30 Tage: 27
Insgesamt: 3,478
