Zum Hauptinhalt wechseln
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
497 Fragen Alle anzeigen
Washer fills and drains but won't agitate or spini
important note: this is about the series 100 washer, not 110. there wasn't an option for the 100
when put on a wash cycle, it will fill and drain repeatedly and won't agitate. when put on a spin cycle, it will spin.
There's no way it's the lid switch, because the washer won't start to fill if the lid isn't closed, and it fills when the lid is closed.
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
Please give us the exact model number so we can better answer your question.
von
110. 24946300
von
Hi @ Kim Forest
What is the problem with your washer?
If it won't agitate, can you manually operate the agitator in both directions?
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Sounds like the “agitator dogs” these are under the center cap of the agitator. They are small plastic wedge looking things, may be 3 or 4 of them.
They cost at the most $10 or as low as $5 for all.
Grab the center piece in tub & turn it back & forth, at some point it should grab & not turn, if not you could probably feel the grinding of the bad dogs.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Kad Ek wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 53
