Zum Hauptinhalt wechseln
A sturdy tablet designed by HP for business and government use.
Why won't the touch screen work unless plugged into power supply
Touch screen won't work unless plugged into power supply
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
I’m assuming that the device works on battery normally aside from the touchscreen, right?
von
Einen Kommentar hinzufügen
1 Antwort
Maybe there is a problem with your internal power supply (battery & wiring).
Check if your battery connector is still properly in place. If yes, you maybe have a damaged or old battery.
It could be that your battery reached the end of it’s life, and it’s not able to deliver enough power to get the screen to work.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
patgee69 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 25
Insgesamt: 292
