Zum Hauptinhalt wechseln
Das Google Pixel 2 ist Googles zweites Flagschiff -Smartphone, es erschien am 17. Oktober 2017. Das Smartphone ist mit einem 5" AMOLED Display ausgestattet und kann mit 64 oder 128 GB Speicher bestellt werden. Erhältlich ist es in drei Farben: Schwarz (Just Black), Weiß (Clearly White) und Blau (Kinda Blue).
65 Fragen Alle anzeigen
Screen repair gone wrong, can't find the culprit
Hi Fixers,
I recently bought a pixel 2 with a cracked screen with the intent of replacing it. I purchased a new screen as well as a new battery. When I plug in the new screen, the device buzzes (indicating it’s at least responding to the power button being pressed) and my computer also recognizes that a device is being attached - so it’s not completely dead. The screen sometimes does a very swift white flash but otherwise remains completely black. I find it somewhat hard to believe that the motherboard’s display connector is broken, but I am at a loss for what else it could be.
One more piece of info that might be important: I can start the device twice by holding the power button, after which I need to unplug the battery in order to get it to respond to me powering it on again. Not sure why this is the case but might be worth mentioning.
Thank you and kind regards!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Did the OLD screen work before you opened it? May be the seller sold you a defective item? Or a rare case may be your new screen is defective!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Lucas Dymanus wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 75
