Zum Hauptinhalt wechseln
Der DeLonghi EC 155 ist eine Siebträgermaschine mit Pumpe zur Zubereitung von Espresso und Cappuccino.
25 Fragen Alle anzeigen
Cleaning the boiler outlet
I can’t get the screw out to clean the boiler outlet. It seems to be welded in. Water won’t pump through. Do I have to throw the whole machine away because the screw won’t come out?
Update (01/08/2020)
Here are the pictures of the screw I can’t get out and the boiler holder (holds the coffee filter).
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
jwsacco post some good pictures of what you are up against. That way we can see what you see and hopefully help you out.Bilder zu einer vorhandenen Frage hinzufügen
von
I can't get the screw out. It's stuck fast. I have tried WD40. Any advice would be appreciated.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
jwsacco it is not welded in. I think it is just hard to get a good grip on it. Use a phillips head socket and a ratchet. Place the socket into the screwhead and use a small hammer to tap the bottom of the socket thus loosening the screw a bit. The use the ratchet on the socket to remove the screw.
Check the first 45 sec off this video
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
jwsacco wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 45
Insgesamt: 2,275
