Zum Hauptinhalt wechseln
Im Juni 2017 brachte Apple die Neuausgabe vom 13" MacBook Air heraus. Es erhielt den neueren Broadwell Intel Core i5 Prozessor, die Leistung und Akkulaufzeit stieg dadurch etwas an.
421 Fragen Alle anzeigen
Can I swap swap SSD from broken MacBook Air 2017 to MacBook Air 2015?
Both are model A1466. I just tried the swap now and when I put the SSD from the dead 2017 into the 2015 in comes up with a flashing folder with a question mark. If I hold down the option button when powering on the only choice is network. Does this mean the SSD is dead or corrupted?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Yes they are compatible. To confirm either of those you’ll need to boot a MacOS installation media (via USB or internet recovery) and check if it is detected under disk utility.
War diese Antwort hilfreich?
Bewertung 4
3 Kommentare:
You could also refer to this great guide The Ultimate Guide to Apple’s Proprietary SSDs
von
Thanks for your answer! I booted into internet recovery and I can see the drive in disk utility and it appears to be ok https://i.imgur.com/OJm8PjJ.jpg
But I don't know how to get it to boot from the drive?
When I go to choose startup disk it's just empty, nothing to select.
von
disk 1 is actually the MacOS Installer media, the top one apple SSD with diskOS2 would be where the macOS is.
It is very likely that the data stored on the SSD is corrupted making it not identifyable as a bootable MacOS SSD.
If data is required I would recommend installing MacOS onto a portable hard drive or another spare laptop drive via a SATA 2.5" to USB adapter. Then you can boot macOS off another drive instead of the SSD and see if it lets you read the information off the SSD that is installed in the Macbook.
von
Antwort hinzufügen
Eric wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 246
