Zum Hauptinhalt wechseln
Smartphone by Huawei, released April 2015. Includes models Y625-U32, Y625-U21, Y625-U51.
22 Fragen Alle anzeigen
My phone doesn't turn on after months discharged
Goos afternoon fellows so here's the thing I used to have an Huawei y625. But then with the black Friday and stuff I bought a new one and left that on the shelf. After a big while like months I was curious if I let any important file on the phone but here's the thing it doesnt turn on anymore. I remember while it was working I had a problem and had to replace the firmware and I did so it started work normally again. So I thought it might be the battery that was fully discharged so I plug it in about 1 hour but it steel does appear nothing on screen not even charging logo. I changed the charger and even plug it into an powerbank and it was drawing power from it but after a while steel nothing. I was wondering if anyone has an idea of what could it be. Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare
Dead screen or dead battery? The battery can sometimes be so flat that it needs to be replaced
von
Im buying a new one just to be sure but supposedly If the problem is the battery should I be able to just use the phone without it or that doesn't work anymore?
von
The phone needs a working battery in order for it to turn on. I recommend leaving it plugged in overnight and see how that goes.
von
Nothing append soo that means that the battery is totally dead?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi, I’m slightly confused, but any electronic needs a battery. After leaving a device uncharged for months can cause the battery to drain completely flat. When this happens, it is hard to charge it up again, so a new one is needed. In stall the new one. It may make the device work but everything needs to be connected up. If it doesn’t work then comment and we will see what else needs to be done.
Also, if you are not sure of how to replace the battery yourself, take it to a reputable repair shop and they will be able to install the new part fairly cheaply.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Tiago Mendes wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 9
Insgesamt: 756
