Zum Hauptinhalt wechseln
Chrysler brachte das Modelljahr 2008 des Town & Country am 16. August 2007 auf den Markt.
Gas gauge only reads 1\2 tank when empty. And speedometer doesn't work
I have a 2009 Chrysler Town and country van and the gas gauge only goes to half a tank when empty no low fuel light nothing and the speedometer has stopped working. I have pulled ever fuse under the hood and none where blown. Have try holding in the trip reset while key is off and then turn on key holing in reset button until gas gauge went to empty and have tried letting go when the gauges start the rest process.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
having an issue with both of them may be a fault inside the instrument cluster itself? The speedometer would fail if there’s problems with the speed sensor, faulty ECU or broken gear in the speedometer system itself. fuel gauge would fail because of bad or faulty fuel sending unit or there’s something maybe catching it in the cluster, I would start with opening up the cluster first to see if you can spot a fault for both in there.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Larry Newman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 23
Insgesamt: 880
