X in battery icon in menu bar. What's up with that?
On the above machine, now I get an X in the battery icon instead of an outlet or thunderbolt. I tried another battery on it. The swap showed the thunderbolt for a little while and then went back to the X.
I don't think that it is the battery since it happened to two batteries at the same time. My guess is that it could be the DC to DC board. BTW, the power adapter is glowing green.
Any suggestions to fix this problem?
Ist dies eine gute Frage?
Thank you for the replies! much appreciated!
I went ahead tried the second battery again. It started to charge and then stopped at 65% and went to an outlet icon in the battery icon in the menu.
I rebooted the machine to get into the charge cycle. However, instead of it charging after the reboot, the second battery too had the X in the battery icon.
I went online and looked at a couple of web pages that discussed the problem. One of the suggestions, was to FLEX the battery area that (for lack of a better word) holds the battery in the computer. After I did this, the machine started to charge the battery. However, it went back to the X after charging it to 65%.
I had yet another battery. I once again flexed the battery area and put in the third battery. I was able to get this battery to recharge from whatever percentage it was on to 100%. I guess the combination of the flexing of the battery compartment and a conditioned battery did the trick.
von Yuri
Glad you got it fixed Yuri. Please post your comment as an answer and "Accept" your own answer this way it can be archived and might help the next person with the same issue. Thanks.
von Majesty
Well, I thought that I had it fixed! However, since the last post, I had the same issue with it again. I even went ahead and changed the DC to DC board on it. Again, it started to give me a percentage and then went back to the X icon in the battery menu. So, it stands this way, now ALL my batteries show an X when I put them in and also, I changed the DC to DC board at least twice! I am going to try another DC to DC board. Any thoughts on what I can do to diagnosis this problem?
von Yuri
