Zum Hauptinhalt wechseln
Reparaturanleitungen für Fahrzeuge der Marke Citroën.
75 Fragen Alle anzeigen
The car doesn't start
my Citroen c8 doesn't start?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare
Could we possibly get some more information?
von
For instance--does the engine turn over?
von
the engine doesn't turn over
von
Since you are really not telling us anything about what your car does or doesn't do. Start witht he basics. Do you have any battery power? Do your dashlights come on? Do your lights come on? Do they go dim when you try to start your car? You need to give more info if you want a definite answer.
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
With a broken timing belt you will have:
bent valves
damaged pistons
possibly bent con rods
Or just a useless timing belt. Do not try cranking the motor over (might lead to all issues mentioned above). Take it to a capable garage!
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
Extremely good advice--you can total a engine with a bad timing belt. +
von
Insert your car's key into the ignition switch and turn clockwise until you hear sounds from the engine bay.
Bewertung 2
1 Kommentar:
the timing belt is broken and it damaged the engie
von
If you have a keyless push button ignition it requires you press on the brake to start. There's a brake pedal switch that performs this function which is a common problem and quick repair.
Bewertung 1
Antwort hinzufügen
solomon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 1,928
