Zum Hauptinhalt wechseln
The first generation (KJ) Jeep Liberty, a compact 4-door SUV. Sold in both 2WD and 4WD configurations.
33 Fragen Alle anzeigen
clicking sound by the fuse box and horn doesn’t work
There’s a clicking sound by the fuse box and horn doesn’t work what can i do to stop till i get it fix
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Sebastian Bermudez  If it only clicks when you press the horn button it is probably your horn relay that clicks and in your case it may be the horn that has failed. Apply direct voltage to the contact of the horn and see if it works. Negative to horn housing and positive to the horn contact where the cable connects to.
If this clicking is a clicking that is there all the time you will have to get closer to it and identify the part that is clicking. you can then go ahead and post some pictures of that so we can try to identify it.
Bilder zu einer vorhandenen Frage hinzufügen
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Sebastian Bermudez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 183
