Zum Hauptinhalt wechseln
Also known as the Mega Drive II, this is a smaller, lighter, 2nd-generation version of the popular Genesis console, released in 1993.
11 Fragen Alle anzeigen
Sega Genesis Controller port does not work
My Sega Genesis 2 second controller port is not working at all, I’ve tried desoldering and soldering the port a couple times. I’ve also reflowed everything on the back of the board and checked continuity from where the controller plugs in to the resisters just in front of where the pins solder to the motherboard. The weird part is in sonic 2 and 3 it actually does kinda work but then gets stuck going left. What can I do that I haven’t already?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
It’s possible you may have a bent or missing pin. Look inside of the controller slot and if a pin is bet you should be able to bend it back, however if it’s missing I would try to find a new connector and solder it on.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Help me wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 6
Letzten 30 Tage: 34
Insgesamt: 446
