Zum Hauptinhalt wechseln
Anleitungen für die Wi-Fi-Version des iPad Mini 2. Angekündigt am 22. Oktober und erschienen am 12. November 2013. Das iPad mini 2, auch bekannt als iPad mini mit Retina Display, hat alle Pixel des iPad Air in einem kleineren 7,9"-Formfaktor.
Why won't my iPad turn on?
Since my iPad turned itself off, while I was using it, I’ve tried resetting it and connecting to computer- neither have helped. When I hold in power and home button the logo screen flickers on, for varying amounts of time and sometimes with part of the screen darker then the rest, and then turns off again before the lock screen.
Update: I managed to turn it on for a few moments, the screen was very dark except around the home button where it was lit up more- it then switched itself off again.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
You have to determine if this is a battery/charging issue or something else. Try these steps to help isolate the issue (in order):
  1. Always try another Lightning cable and charger, preferably Apple original or MFi certified units. Does an iTunes enabled computer recognize the device?
  2. The Lightning cable 8-pin connector should be sitting flush with the housing and completely inserted. If it is not, there could be lint/dust/debris inside the port impeding a proper connection. You can clean it out with a toothpick, fine point tweezers or a dental pick. Just be careful not to damage the pins inside the Lightning Port.
  3. You can use a USB Ammeter to determine if the device is really drawing current when it says it's charging. If it isn't drawing current, then it could be a bad charge port or battery.
At this point, you need to get back to us with more info on your troubleshooting. You may also need to start replacing stuff, which means opening your device. Check out this guide to see if you are comfortable with the work required.
War diese Antwort hilfreich?
Bewertung 4
it has died or the batry died
Bewertung 0
it has died and you can take it to i place to fix it
Bewertung 0
Antwort hinzufügen
particleman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 40
Insgesamt: 647
