Zum Hauptinhalt wechseln
Verkaufsstart Juni 2012, Model A1278. Intel Prozessor mit Turbo Boost, bis zu 512 MB DDR5 Video RAM
1649 Fragen Alle anzeigen
Can I swap my old hard drive into my new machine?
My 2011 MBP suffered from a dead short by the LVDS connector, which burned the board :-(. The problem is the cost of repair the damage was about as much as a replacement system, so I decided to get a identical 2012 instead. I’m not happy about why I had to buy it, but my hard drive is fine so I can make it like nothing ever happened by swapping the drive over.
Anyway, everything else about it is fine outside of the screen and board - including my hard drive so I still have plenty of reusable parts to pick at. I can drop the old hard drive into my new machine and be back where I am, but my replacement shipped with Sierra AND I updated to High Sierra (no APFS). To make it so I can run it for data recovery, I put Kapton tape over the LVDS connector and LVDS cable so I don’t have to worry about the short. Since my replacement is not on High Sierra, I don’t know what kind of updates I need to run to get the EFI firmware current or if it’s even an issue at all.
Once I install High Sierra and check the EFI is current, is it still possible to switch hard drives between systems with very similar hardware? I know it worked in the past but the EFI updates changed things dramatically.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hope I understood you corectly
A Macbook Pro 2012 with a High Sierra install can run a lower MacOS hard drive but a Macbook Pro 2011 cannot see a High Sierra formated (APFS) drive
War diese Antwort hilfreich?
Bewertung 2
Kommentare:
What I want to do is remove the drive from the 2011, update the new one to High Sierra WITHOUT APFS (Not ideal for spinning rust) for EFI insurance and just have a newer machine. I'll take on the APFS upgrade when I get an SSD.
von
@nick yes you can take the old drive and do the update
von
Antwort hinzufügen
Nick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 75
