Zum Hauptinhalt wechseln
Die 2013er Neuauflage des Mac Desktops, bekannt als Mac Pro.
117 Fragen Alle anzeigen
2-3 second grinding noise on startup
There’s a short (2-3 second) grinding noise at the beginning of startup, before anything appears on the screen. I’ve taken the cover off and the fan is rotating ok. Any idea what it might be? It works ok, just worrisome.
Update (03/14/2020)
I replaced the fan. It doesn’t work. I think I may have damaged one of the electrical ribbons, going to see if shop can fix. But also, still have the grinding noise. Video attached.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Has to be the fan.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
A grinding noise implies physical movement, and as the only moving part inside the Mac Pro is the fan that kind of narrows the possibilities.
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
I know, but the fan spins freely no noise, after shut down and opening the can. What initiates the fan movement on startup?
von
The fan is little more than a self-cooling electric motor. I would guess that the fan is either slightly off-balance or the bearings are slightly worn, and at startup (low RPM — but faster than you can spin by hand) it wobbles enough to make noise. Once it gets up to speed it stabilizes enough that it stops making noise. If this is correct, your fan will get gradually worse until it fails completely.
von
Thanks. Makes sense. Find a new fan and do this: Mac Pro Ende 2013 Lüfter tauschen. Some of the comments under this sound familar.
von
There is a non-moving part that can make a noise.
von
Antwort hinzufügen
John Cathey wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 418
