Zum Hauptinhalt wechseln
Modell A2159, EMC 3301. Eine Neuauflage des Einstiegsmodells des MacBook Pro. Erhältlich in Silver und Space Gray. Erschienen im Juli 2019.
109 Fragen Alle anzeigen
Replace the MacBook Pro 2019 keyboard
my macbook keyboard doesn't work, because I don't want to replace the warranty period, I searched for references and haven't found it yet.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I would strongly recommend you rethink your direction here!
Apple offers an extended warranty program for butterfly keyboard failures. If you have a bad key or multiple keys Apple will either fix the single key of replace the entire uppercase with a new keyboard.
Replacing a keyboard is quite an intensive a project! In Apples wisdom they rivet the keyboard in! So you’ll need to drill out the rivets without damaging the uppercase, Then you have the next problem which is finding the 4 Generation keyboard which is what your system had.
In the end you’ll spend a lot of time and the results won’t be as good as what Apple’s uppercase rebuilders can achieve with custom tools and lots of experience! If they mess up it goes into a trash bin and move on, what are you going to do if you mess up?
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
asreds.claten wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 39
Insgesamt: 1,714
