Zum Hauptinhalt wechseln
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
280 Fragen Alle anzeigen
USB/Ethernet/all ports not working
The USB/Ethernet/all other ports on the back of my iMac have stopped working. I plugged a USB cable in and it touched a lamp with a short--it arced and now the USB and Ethernet don't work. The computer boots seems to work fine, but I can't interact with it via keyboard/mouse/ethernet. The airport is off so I can't try connecting via wifi.
My guess is the bus with the ports has been fried. Is this on the logic board, or is it a separate board that's easier to replace?
In addition, any ideas on how to connect/interact with the computer without the use of USB/Ethernet/Wifi?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
You're probably looking at having to replace the logic board. You may be able to get to the bluetooth by disconnecting your keyboard and starting up.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
if you have a bluetooth module, you can try using a bluetooth mouse and keyboard. your imac should ask you pair a keyboard and mouse if you have the bluetooth installed.
as for the damage, the ports are part of the logic board. i have never seen the come seperate. i would have to say
Bewertung 1
Antwort hinzufügen
Reed wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 922
