Zum Hauptinhalt wechseln
Mobilversion von Apples iPad Air der 2. Generation. Modellnummer A1567
78 Fragen Alle anzeigen
Why does my screen look distorted?
Recently I sent my iPad to be fixed for broken screen (the LCD was intact), they separate the digitizer from the lcd and put a new digitizer on and keep the original lcd.
They did a good job fixing it, but after a day it began to have a distorted screen when I wake up the iPad. It goes away and function normally after a couples of seconds and sometimes for longer. When it goes away the screen looks and functions completely normal, the problem only occurs when the iPad is left a couple of hours not used.
It’s a odd problem, could it be loose cable fitting? Have anyone of experienced the problem before?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Either a loose cable, highly unlikely if they put the metal cover back over the screen connectors or the screen has gone faulty, probably their bad luck from refurbishing the screen.
I have only experienced one similar problem like this but with a full grey screen and rarely showing normal display when trying to lock and wake it up, this is from getting a replacement screen from a supplier (refurbished ones), bought like 10, one comes up like this.
Have to return to back to where it was repaired for warranty :S
War diese Antwort hilfreich?
Bewertung 2
Kommentare:
Thank you for reply, I think I will try to open it up and check if there’s any loose cable
von
Antwort hinzufügen
Mohammed wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 132
