Zum Hauptinhalt wechseln
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
Why wont my phone charge?
I dropped my phone and it will not charge after the drop. When plugged in, it turns on and off on a cycle and the battery logo comes on. It will show the logo for a few seconds and then continue on a loop.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Cesar Ramos  the looping can be an issue with the battery/power. Check to make sure that the battery is still fully seated and that it makes proper contact and that the battery flex is not tore. You will have to do a bit of disassembly for that. In your phone case and if this still the original battery, I would replace it at the same time. HTC One M8 Akku austauschen
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Cesar Ramos wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 121
