Zum Hauptinhalt wechseln
Modelle A1237 oder A1304 / 1,6, 1,8, 1,86, oder 2,13 GHz Core 2 Duo Prozessor
MacBook air (mid 2009) beeps every five seconds after keyboard connect
Hi!
So, I was trying to fix a mid 2009 (A1304) macbook air and concluded the keyboard was probably broken. So, I disconnected the ribbon cable for the keyboard and started the macbook using the power pads, and it worked!
Genius as I am, I (let’s say accidentally) reconnected the keyboard ribbon connector while the computer was booting. After that, it will only give me a beep every five seconds.
Now, I know this is stating there is a ram problem, but since the ram on a macbook air is soldered onto the logic board… does this mean this macbook air is probably fried?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Ouch! Not good!
Yes you do need to make sure things are off before connecting or reconnecting things. Time for a new logic board sorry ;-{
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
If that's the case, it's time for the trashcan
von
Antwort hinzufügen
Timbobs wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 107
