Left Joy-Con dead, doesn't work attached to the switch or not
My Joy-Con has been dead for a while. It doesn’t even turn on, no lights flash on the side rail while on the Switch or off. I have opened up both controllers, and swapped the battery as the right Joy-Con still worked. Good battery doesn’t work. “Bad” battery found in dead JC works on good Joy-Con. Not a battery problem. Any help is greatly appreciated. Thank you!
Ist dies eine gute Frage?
OK so i have fixed a few dozen Joy-cons and to my Knowledge it is a slider rail problem in the slider rail it contains the charging port at the bottom of the joy-con when slid into the switch console. a replacement rail should be fairly easy to acquire through such sites as amazon / ebay / Aliexpress etc.
von p_smith
Thanks p_smith, I've just ordered some rails from Aliexpress
von Rob Loewen
@p_smith I fixed mine, it was a motherboard issue
von Brady Cook
@wispysmoke what did you replace/fix?
von Wyatt
@mrwyyeet The entire motherboard. I have a boneyard of joy-con parts, and found a spare working motherboard. It turned back on and worked swimmingly. Not sure which part on the mobo went dead but figured it was a mobo issue.
von Brady Cook
1 weiteren Kommentar anzeigen
