Zum Hauptinhalt wechseln
Jeans are comfortable, everyday pants usually made from tough yet comfortable denim.
4 Fragen Alle anzeigen
How to repair holes in the crotch of my Tenpenny Pants
My Patagonia Tenpenny Pants have developed some holes/rips in the crotch. Most of my trousers do this eventually. Is there a repair I can make to get more life out of them? They're made of cotton/polyester
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Chub rub! Also my primary failure point for all Pataguchi pants. There MUST be an easier repair than just loosing weight.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You can do an iron on patch:
Einen Bügelflicken anbringen
The zig-zag patch requires a sewing machine:
Zickzack-Flicken
Patagonia Jeans Bild
Anleitung
Zickzack-Flicken
Schwierigkeitsgrad:
Leicht
10 - 15 minutes
Patagonia Jeans Bügelflicken anbringen Bild
Anleitung
Schwierigkeitsgrad:
Leicht
5 - 10 minutes
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
I saw those,but I wasn't sure if they would work on a non-flat bit of the clothing (the crotch is a kind of saddle shop on most clothes)
von
I've done it on elbows. I put a patch on both sides and sometimes hand stitch the corners down so they don't curl up. eBay has patches but most come in from China (I've had a set of denim patches ordered now for a couple of weeks but the shipping now says VOID). You can probably find them in the states just at a higher price.
von
Clothing starts out as a flat piece of fabric and has curved seams to fit your shape. You can smooth down the area to where it’s flat and add a patch. You’ll follow the curved seam to keep the shape. If you are hand sewing use a back stitch which is strong and won’t loosen. For a source of patches try your local fabric stores. You don’t have to use a precut patch, you can cut your own from new fabric or my favorite, old pants ( which are already softened from wear). Denim will fray on a cut edge so just put the patch on the inside if that’s not what you like. or enjoy an edgy look.
I love that ifixit supports repair solutions!
von
Antwort hinzufügen
Matt Freake wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 57
Insgesamt: 2,054
