Zum Hauptinhalt wechseln
Modell A2159, EMC 3301. Eine Neuauflage des Einstiegsmodells des MacBook Pro. Erhältlich in Silver und Space Gray. Erschienen im Juli 2019.
110 Fragen Alle anzeigen
I dropped the MacBook on it's aux port and it is now deformed.
Hi,
I dropped a new macbook pro when unloading the car after a skitrip. It was in a protective cushion, but it fell on a corner and I think it hit the harder zipper area of the casing (the zipper area also broke there). The fall slightly deformed not the bottom case of the laptop, but the case that holds the keyboard, touchpad, etc…
The casing got deformed just around the aux port so that I can’t plug headphones in anymore. I don’t know if it also broke the aux port itself, but I would think not.
Does anybody know how hard I F’d up or is it quite possible to replace this casing?
Thank you for any help!!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Ouch! Did you take out AppleCare+ extended warranty? If you did that will be your cheapest way to get this fixed.
Getting the uppercase replaced is also possible. You’ll need to get the correct version based on the keyboard you are using, as an example review this listing [B661-12993|13” MacBook Pro - Top Case & KB UK] you’ll need to contact TheBookYard to find out when they expect new stock of the version you need. I’ll warn you it will likely be awhile!
If you can live with the damage you could get a USB-C to headphone jack DAC adapter so you can plug in a headset or external speakers.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Hello,
No I haven’t taken any extra warranty. I think I will probably have to start using a USB-C to jack DAC adapter then indeed. Might pass by some repair shop and see how much they would bill me to get the top case replaced, since I’m having trouble finding it online. Would it even be an easy repair? I know my way around a laptop, having fixed some macbook batteries, but haven’t tried my hand on any advanced stuff.
von
Antwort hinzufügen
Stefaan De Waele wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 122
